Scenic MK2 2007
petar
Prispevkov: 6
Pridružen: 03 Okt 2019, 08:15
Scenic MK2 2007
Odgovor Napisal/-a petar »
Hello folks,
I'm new here and sorry for writing my first post in English since my Slovenian language is not very fluent now but I'm learning it.
I have bought a Scenic MK2 from 2007 1.9 dCi and I want to find a good car service in Maribor or near by.
Do you have some suggestions? Also I have an issue with one of the wipers and that needs to be fix immediately.
I want to change the leather from the steering wheel. Is there some service who can change this?
Thanks.
gusti4u
Prispevkov: 52
Pridružen: 31 Jul 2006, 20:59
Kraj: CELJE
Re: Scenic MK2 2007
Odgovor Napisal/-a gusti4u »
Si sposojam temo....
Ali ve slučajno kdo za kakšnega Scenica letnik 04-08 2.0 turbo?
Ali obstaja sploh kakšen pri nas? Ni važno ali je Grand ali mali!
petar
Prispevkov: 6
Re: Scenic MK2 2007
gusti4u napisal/-a: 19 Mar 2021, 09:38 Si sposojam temo....
Please try to translate in english so I can understand what your question is.
Thanks! :)
robertp
Prispevkov: 1624
Pridružen: 29 Jul 2005, 08:13
Kraj: Vodice
Re: Scenic MK2 2007
Odgovor Napisal/-a robertp »
Faza 2 ni več imela 2.0 TCe motorjev. Samo 2003-2006.
gusti4u
Prispevkov: 52
Kraj: CELJE
Re: Scenic MK2 2007
Hvala za info...
Torej iščem scenica 2.0Tce do letnika 06. ;)
robertp
Prispevkov: 1624
Kraj: Vodice
Re: Scenic MK2 2007
Govorim iz izkušenj... 😀 ker drugače bi ga kupil dam, tako sem v GS Privilege imel na voljo samo 2.0 16V, 1.9 dCi in 2.0 dCi Proactive
petar
Prispevkov: 6
Re: Scenic MK2 2007
Pa dali ste procitali prvi post temi? Sta se trazi u ova tema?
robertp
Prispevkov: 1624
Kraj: Vodice
Re: Scenic MK2 2007
A jel si posle skoro 2 godine našao servis u Mariboru? Inače je sve OT...
petar
Prispevkov: 6
Re: Scenic MK2 2007
Znam da su skoro svi offtopic postovi i zato sam reagovao ali ovde kako nikog zivog da nema. :shock:
Pa godini i po smo u karantinu, tako da jos trazim servis ili majstora u Mariboru.
Nasao sam jednog za malog servisa ali nije znao da pogodi ulje za dCi sa dpf filtrom i nisam zadovoljan. Zato jos trazim nekog kog ne bi trebao da savjetujem koje ulje ili koji drugih delova da uporablja.
Sad mi je potreban neko ko moze da zameni grejace na dCi motora.
Jel znate netko ko moze to da uradi? :roll:
gusti4u
Prispevkov: 52
Kraj: CELJE
Re: Scenic MK2 2007
Poizkusi pri Grgo Bandur.
petar
Prispevkov: 6
Re: Scenic MK2 2007
gusti4u napisal/-a: 23 Mar 2021, 13:47 Poizkusi pri Grgo Bandur.
To je "Servo-Trg"?
gusti4u
Prispevkov: 52
Kraj: CELJE
Re: Scenic MK2 2007
petar napisal/-a: 23 Mar 2021, 14:03
To je "Servo-Trg"?
Meljska cesta 60, 2000 Maribor
petar
Prispevkov: 6
Re: Scenic MK2 2007
Grgo je zaposlen u Servo-Trg?
