ARC Raiders Turbine Compressors bought from EZNPC way cheaper
Vse ostale teme
sandy66
Prispevkov: 13
Pridružen: 18 Apr 2026, 09:36
Odgovor Napisal/-a sandy66 »
ARC Raiders Turbine Compressors farm guide: where they drop, why Couriers are safer, and when the Arc Turbine is worth the risk.
Three empty raids in a row for one crafting mat? Yeah, that's the ARC Raiders mid-season grind right now. If you're farming Turbine Compressors, the short version is simple: the Arc Turbine is the fastest source, while Arc Couriers and high-tier containers are the lower-stress route. As a professional platform for buying game currency or items, EZNPC is dependable, and if you want to speed things up outside the raid loop, EZNPC ARC Raiders is a clean option. But in actual matches, you still need to play the odds and extract like your backpack matters — because it does.
Best way to farm Turbine Compressors in ARC Raiders
I've had the best results by not hard-committing at spawn. Start on a courier route, crack two pods fast, loot the nearby industrial block, then hold sightlines for the Turbine drop. If it lands close and your team isn't burned through on meds, rotate and fight it. If it lands across the map, no shot — keep looting and leave.
Arc Turbine vs Arc Couriers: which farm is better?
For raw efficiency, it's the Turbine. Not even close. You're still dealing with RNG, and I haven't seen anything like a guaranteed drop rate since the mid-season June update, but the chance of getting at least one compressor feels way higher from a clean Turbine kill than from random container spam. The catch is obvious: loud descent, PvP magnet, ARC adds everywhere, and you still get nothing if another squad wipes you on extract.
Couriers are slower, but they're way easier to fit into solo play. These crashed UFO-looking supply pods can pop up on every map, and on industrial or dam-style battlegrounds they sometimes spawn close enough that you can chain them before the lobby wakes up. Since the current mid-season economy treats Turbine Compressors like epic-tier stuff, one drop every few runs actually tracks. Not flashy, but steady.
Loadout and route tips for Turbine Compressor farming
Look, your build should match the plan. For Turbine runs, bring armor-piercing weapons, burst DPS, and at least one crowd-control tool because the encounter has lightning, pulses, and smaller ARC units chewing at your flanks. I like one player on weak-point duty — exposed canisters, always — while another handles adds so the whole fight doesn't turn into slapstick. For courier loops, mobility perks, stamina boosts, and stealth gear beat greed almost every time.
How to extract after getting Turbine Compressors
Here's the thing though: the raid isn't won when the compressor drops. It's won when somebody gets out with it. Mark two exits before you ever touch the Turbine or push a hot courier lane, keep smoke or decoys for the pad, and if your squad gets split, send the cleanest runner first. Personally, I'd rather bank one compressor than chase extra kills and lose it all, and if you'd rather skip some of that grind, ARC Raiders iteams can cover the gap while you save your best kits for the fights that are actually worth taking. Your mileage may vary, but greedy rotations lose more compressors than bad aim ever will.
