R5 GTT by luis klaro
hmm...sej si ne izmisljujem kaj ima, pac je moj najboljsi kolega, sm mu pomagal montirat vse te stevcke....in ja vem kaj je...tisti knofi so, ker lahko gor priklopis lucko in zvocnik...in nastavis vrednosti(max in min) kjer naj se ti vzge alarem (in zacne piskat in svetit da te opozori) in se neke fore imas, ki tocno ne vem ker se nisem poglabljal.....mislim da imas tudi opcijo med C°in F°......jero_13 napisal/-a:in zakaj bi pol meu knof set? Pomoje je res turbo timer tole.Dariooo napisal/-a:temperatura izpušnih plinov
evo kaj imas vse v paketu senzorja in stevckaDariooo napisal/-a:na kaj ciljas, da izves neki novega...na uporabo stevcka...al na uno drugo?!jero_13 napisal/-a:Aha, interesantnoVsak dan zveš nekaj novega
Koda: Izberi vse
EGT, or exhaust gas temperatur - a very important indicator for a well working engine.
All serious tuners arround the world use ETG gauges for checking their work at the engines.
You can check peak values (min/max) of temperature with only one click. You also can check how long you have reached the peak temperture.
The relay output you can use for optical and acoustical warning signals or WAES activation, fans for coolers or deactivate NOS Systems.
This is the best priced professional ETG gauge on market!
Compact size therefore easy to fit into most machines (24 x 48 x 75 mm or 1x2 x3")
Supports every type of commonly used temperature sensor inputs.
Displays maximum, minimum value and its occurrence time with a single touch of key pad.
Bright LED display that is easier to read than LCD display used on most thermometers.
Alarm output when temperature/parameter is out of range.
Can display temperature in either Fahrenheit or Celsius.
Four digits LED display can go up to "9999" or 0.1 degree resolution (with Pt100 RTD sensor)
Adjustable display brightness that can be synchronized with headlight.
Tow point calibration for high accuracy
Relay output
malo dolgcasa pa je padlo neki fotk....malo nas je vreme zezalo, ampak se da vse popravit
Danes je šel prednji odbijač na obdelavo, pol se bodo še ogledala pobarvala v barvo, treba je še dat gor napit na zadnja vrata, čepek od ključavnice...še nekaj dela je, ampak malenkosti
Zadnjič spremenil Dariooo, dne 17 Jan 2010, 23:48, skupaj popravljeno 4 krat.
